07-19-2022 11:26 - edited 07-20-2022 13:42
We’re excited to announce that a firmware update for Charge 5. Some of you might already have this update available. If you installed it, let us know what you think!
We release updates to customers in phases. If you don’t see it, check the Fitbit app in a few days, and you’ll see a message when you can install the update. We appreciate your patience while we get this update to all of our customers.
WHAT’S NEW AND FIXED
See What's changed in the latest Fitbit device update? for release notes.
HOW DO I UPDATE?
See How do I update my Fitbit device? for step-by-step instructions for updating your Charge 5. If you run into difficulty updating, see Why can't I update my Fitbit device?.
We’re interested in hearing your feedback on this update! Let us know what you like! If you encounter unexpected behavior during or after your update, please post the details below.
09-09-2022 15:40
09-09-2022 15:40
09-09-2022 16:55
09-09-2022 16:55
Hoping you have positive results and looking forward to your update.
09-09-2022 18:19
09-09-2022 18:19
Ever since this update my fitbit is stuck in the reboot cycle. I have gone through so many forums following customer supports steps to troubleshoot for my charge 5, but even thought i was able to ( by many tries and a few literal miracles) i was able to to change the clock face and re-pair the device, and it changed nothing except make the reboot window even shorter. My watch is unusable now
09-09-2022 19:39
09-09-2022 19:39
Yes, a transcript of the conversation was saved. Will update in the morning, so I don't lose today's data.
09-10-2022 00:46
09-10-2022 07:37
09-10-2022 07:37
09-10-2022 07:50
09-10-2022 07:50
09-10-2022 08:09 - edited 09-10-2022 08:11
@SteveCDNWhile I agree with you I do not see that they actually care about the costs you list. No official response, only private responses on a case-by-case basis with inconsistent action. No acknowledgement anywhere of the cause(s), or even that it exists. No accepting of responsibility. Nothing...
All they needed to do was say "Oops. We were very concerned about a new day-0 security exploit and the fix unfortunately caused unanticipated problems for some small percentage of our users. Contact us and we will make it right." Done...
What an unnecessary fiasco...
Instead they continue to brick countless Charge4, Charge5, Versa2, Versa3 models and a couple of others all while damaging the brand and continuing to generate a lack of trust for the entire FitBit name and ecosystem.
09-10-2022 08:15
09-10-2022 08:15
09-10-2022 08:22
09-10-2022 08:22
09-10-2022 10:33
09-11-2022 17:48
09-11-2022 17:48
@radesix For some of us, the firmware update would restore the ECG function that didn't exist in the 1.142.37 version of firmware. Replacement pebbles are being shipped with that version of firmware. So updating the firmware would introduce something new (if the upgrade works).
09-11-2022 18:15 - edited 09-11-2022 18:15
I have been hearing of conflicting information about the updates on multiple models. For example, the Charge4 and the Charge5 both are failing in similar ways after their most recent update at the same point in time, but only the Charge 4 lists the security issue.
The same results with the Versa3 and Versa2 Only one lists the security fix but both are being bricked by their latest updates showing up at the end of July, beginning of August.
The release notes are almost useless and provide nothing about what was actually fixed. This creates a host of items like:
The symptoms are the same or nearly so
The timing is the same
Are they suffering from the same security bugs even though they are not listing the security patch on all the models?
Is the fix causing the failures related to the security fix and did all the models then really need/get the security patch?
Which other models are affected?
With such a complete lack of official response from FitBit, how will we ever know?
https://help.fitbit.com/articles/en_US/Help_article/1372.htm
Look at the version numbers for example:
This release includes an update to the Fitbit OS. For more information, see
However, the actual versions listed look like this:
What's changed in the latest Fitbit OS update?
Updates to Fitbit OS provide new features, improvements, and bug fixes for your Fitbit watch.
OS 5.3.1 (Sense and Versa 3 only)
OS 4.2.3 (Versa, Versa 2, and Versa Lite Edition only)
OS 5.3 (Sense and Versa 3 only)
OS 5.2.1 (Sense and Versa 3 only)
We asked them about this previously and they had to look up each version to tell, but there was nothing written we can refer to or read.
09-11-2022 19:19
09-11-2022 19:19
How to i roll this update back. It doubles my heart rate constantly. This makes trscking zone minutes useless.
09-11-2022 19:54
09-11-2022 19:54
FitBit will not allow roll-backs.
09-11-2022 20:01
09-11-2022 20:01
What is a replacement pebble?
09-11-2022 20:04
09-11-2022 20:04
The pebble is just the Charge 5 unit after removing the band. I only had to send that in for replacement.
09-11-2022 20:05
09-11-2022 20:05
When they first came out without their case they were very small hard and smooth all around like a big pebble. They were held in place on a band or in a waist band clip by the rubber shaped slot they were squeezed into. Sometimes they had the nickname of a "pebble". Nothing official I know of.
09-11-2022 20:06
09-11-2022 20:06
Thank you!
09-11-2022 20:08 - edited 09-11-2022 20:10
It seems clear from all the public forums, like here, Facebook, Twitter, etc... that they have REALLY screwed up these recent updates on several platforms.
You can open a case up with FitBit Support and if you are under warranty and they can't fix it they will send you another. Otherwise they just let you have one of the older models at a 35% discount. Discounts don't apply if you want a newly announced model or one of the others excluded from their list..
