09-06-2021
09:27
15:50
SilviaFitbit
09-06-2021
09:27
15:50
SilviaFitbit
I have had two Charge 4's where the connection between the unit and band has broken . The first one was replaced. The second just happened. Is the band connection the same on the Charge 5? If it is I'll be passing on Fitbit until it changes. I do really like the units.
Thanks,
Jim
Best Answer@JimNS3K Check out this YouTube video. At 1:25, there is a view that shows just the Charge 5 pebble with no band attached. The connection is different from the Charge 4. There is no "prong" sticking out. It looks like my Versa 3 connection.
Laurie | Maryland
Laurie | Maryland
@JimNS3K looking at the replacement bands that are found in the fitbit store. And seeing that the Charge 5 band is for only the Charge 5, I doubt they will be interchangeable.
I really like the Versa 3/Sense bands and also the Luxe band.
My biggest issue with the Charge was the initial trying to attach.
