05-23-2023
09:16
13:47
ManuFitbit
05-23-2023
09:16
13:47
ManuFitbit
Hello helpful people -
Is there a way for me to configure the Charge 5 so that
Maybe this is a matter of finding the right clock face?
Here's why I'm asking: I've purchased a Charge 5 to replace an old wrist heart rate monitor. The Charge 5 is clearly overkill but I thought I'd have fun with the extra bells and whistles. However I can't get what I want most: HR monitoring always on screen while I'm working out.
Thank you for your help
Moderator edit: clarified subject.
Best Answer05-23-2023 13:17
05-23-2023 13:17
If you are using the Exercise App, it shows a stat on middle row of screen; tap to change stat displayed. One of choices is heart rate.
Best Answer05-23-2023 20:04
05-23-2023 20:04
Thank you for taking the time to reply. I've tried that, and perhaps should try it again, but it seems like the screen shifts on it's own to some other screen.
Best Answer05-25-2023 08:11
05-25-2023 08:11
Since you are interested in seeing your HR at a glance, I suggest a clock face that displays that metric. I use the Runliner clock face since it displays HR without having to scroll to another screen. The other clock face that displays HR is Slashed.
Best Answer05-25-2023 09:00
05-25-2023 09:00
Best Answer05-26-2023 08:09
05-26-2023 08:09
If you want a calm looking display, try the one called Target. It has 5 symbols on the screen including HR. Tap the screen to change it to the one you want to always see. It stays on your choice until you change it.
