Is mapping possible with the Charge 5?
Right now I have been using a program on my iPhone to may the routes I walk/run. I was wondering if the Charge 5 can map out my routes also and if so, is this a Fitbit App or something else? I would like to be pointed in the right direction if possible. Thank you.
3 REPLIES 3
@Quinn1 Welcome to the Fitbit community!
Your Charge 5 has GPS built in. So it can track your walk/run as long as GPS reception isn't blocked. If you sync your device with the Fitbit app on your phone afterwards, it will show you a map and detailed stats about that exercise.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2
Hi thanks...thats what I meant. I am sync'd but can not find within the app the mapping.
@Quinn1 To get there, just tap on the exercise tile on the Today page of your Fitbit app. Then scroll to find the corresponding exercise and tap on it to get detailed information and the GPS map.
If you don't see the exercise tile in your Fitbit app, tap on Edit in the upper right corner of the Today page and scroll to find the exercise tile. Tap on it's Plus sign and then on Done in the upper right corner.
Stefan
