12-14-2021 21:19
12-14-2021 21:19
It is minor, but annoying. The alarm goes off and you hit snooze. The watch continues to buzz, and buzz, and buzz. This would seem to be an easy software fix????
12-14-2021 23:48
12-14-2021 23:48
Hello again @DaveBohl
I haven't heard much about this particular suggestion. It might be an idea going to the Feature Suggestions for Trackers and checking if it's been submitted. If it hasn't, how about making a suggestion there where it will be seen by people who could change things in the future?
Good luck!
Best Answer12-18-2021 21:41
12-18-2021 21:41
I go there, but the make a suggestion area is greyed out.
Don’t worry about it.
Best Answer12-18-2021 22:02
12-18-2021 22:02
Sorry about that @DaveBohl
Does this link work for you?
You have to enter your search term, check any related posts that come up, then press None of these match my suggestion, and then you can write your new one.
I hope that works for you! If it does, post a link and we can vote for it too!
