08-11-2022
10:22
07:48
DavideFitbit
08-11-2022
10:22
07:48
DavideFitbit
Lost 5th Fitbit broke rubber piece went dead can’t locate on iPhone tracker What’s the problem I sai
Fitbit dead can’t make noise want replacement had for 3 weeks 5th one
08-19-2022 07:47
08-19-2022 07:47
Hi, welcome to the Fitbit Community forums, @Cedar22.
I'm sorry to see that your Fitbit device is now lost and that you had this problem with the wristband.
There are some steps that you can try to see if you can find your device in case it's still nearby. You can find all the recommendations in this article.
However, if you're not able to find it, I would still recommend that you get in touch with the Customer Support team so they can let you know if there are any other options available for you. You can click here to get connected.
See you around.
