01-22-2023
01:26
10:04
DavideFitbit
01-22-2023
01:26
10:04
DavideFitbit
While walking and using Charge5 GPS, low battery warning shows after two hours, Fitbit turns off. When put to charge shows 53% battery remaining.
01-24-2023 10:04
01-24-2023 10:04
Hi, thanks for sharing this information about the issue you're experiencing with your Charge 5, @Kernow55.
Keep in mind that if you use built-in GPS continuously, Charge 5 has a battery life of up to 5 hours. However, since you also mentioned that you do see battery life remaining after the device turns back on, please try completing the three pulse restart as well and let me know if you continue to have the same problem afterwards:
