01-09-2022
05:23
08:24
DavideFitbit
01-09-2022
05:23
08:24
DavideFitbit
I can get this to work maybe 1 time out of ten. I find the position of the fingers required is itself annoying and stressful to me. And 3 minutes is a long time to hold it. This and the readiness feature are of dubious value at best.
01-11-2022 15:35
01-11-2022 15:35
Hello @coolcash
I only used the EDA feature once out of curiosity and didn’t get much from it either.
I did notice though that you can edit the length of time needed by swiping up from the little arrow at the bottom of the screen so you’re not restricted to 3 minutes if that helps at all.
01-11-2022
08:23
11:14
01-11-2022
08:23
11:14
Hi, welcome to the Community forums, @coolcash.
Thank you for sharing your feedback about the Mindfulness Tracker and the Readiness Score.
I noticed a few ideas posted in the forums about improving some of the features included with this device, but I haven't seen one posted about these features.
I would recommend that you post these ideas in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers. Make sure to post your ideas including as many details as possible.
Thank you again for taking the time to share all your feedback.
Have a great day.
Best Answer01-11-2022 15:35
01-11-2022 15:35
Hello @coolcash
01-20-2022 11:03
