10-18-2023
10:12
11:03
EstuardoFitbit
10-18-2023
10:12
11:03
EstuardoFitbit
My poor Fitbit just can't keep up. It seems that it will only work for 1 day. It blanks out, I try to reset it using the 3 pulse reset, Its helps for 1 day. I made sure its UpToDate yet it doesn't want to work. I've lost step & sleep data and getting ready to give up.
Today I charged it again, when I plugged it in the watch said 86%. I'm so lost.
Its 2 years old and maybe that's its life expectancy.
Moderator Edit: Clarified Subject
10-18-2023 11:13
10-18-2023 11:18
10-18-2023 11:18
Hello @skw56
When my Charge 5 had sudden loss of battery, I restarted and recharged it multiple times over several days. This process eventually got my device "unstuck" and the battery went back to lasting 6-7 days. Although there isn't a guarantee that this will work for you, it might be worth a try.
10-19-2023 06:59
10-19-2023 06:59
Thanks @RiekoC, for the recommendations.
I'm pretty sure it is another way to get issues like this one resolved. I hope this really helps others.
