10-12-2022
13:13
12:53
DavideFitbit
10-12-2022
13:13
12:53
DavideFitbit
My Change 5 is not syncing and telling me that batter is critically low. I charged it two days ago-all the way. On the app it’s says I’m fully charged. Anyone else having this problem or experienced this in the past? What can I do? Currently charging device to see if that works
Moderator edit: format
12:52
09:15
10-14-2022
12:52
09:15
Hi, I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5, @1_fit_mama.
If you haven't done so already, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here.
Regarding the device telling you that battery is critically low, if the device is not syncing, the battery level will not be properly updated on the Fitbit app. If the Charge 5 is not charging properly, please try the recommendations listed in this article.
I'll be around.
10-15-2022 01:01
10-15-2022 01:01
Mine got low after 12 hours from a full charge then died. Just won't charge or reset or anything. Only 3 months old too 😫
Hope you get it sorted.
10:58
09:15
10-29-2022
10:58
09:15
@Becca_masters Thank you for confirming that you already tried all the troubleshooting steps suggested earlier.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've provided you with some instructions. In this case, they will let you know how to proceed.
Have a good day.
