09-19-2022 19:45
09-19-2022 19:45
It has always been a bit temperamental about getting exactly connected properly to the charger but now it won't connect at all. Is it the charger or the Charge 5.
09-21-2022
17:06
16:14
09-21-2022
17:06
16:14
Hi, welcome to the Fitbit Community forums, @Montwoman.
Thank you for the information provided regarding the issue you're experiencing with the Charge 5.
Before considering other options, if this is related to the battery, please make sure that you've followed the steps provided in this article.
If the device is charging, but the screen is completely black, make sure that you've also completed the restart procedure with the charging cable as described here.
I'll be around.
Best Answer09-22-2022 00:08
09-22-2022 00:08
I’m having a very similar issue. I’ve tried everything Fitbit has said to do but it seems like the connectors just don’t want connect. I’m about at my wits end and seriously considering going with a different brand of tracker. I’m actually charging up my old charge 3 simply out of frustration
11:41
16:14
10-12-2022
11:41
16:14
@cvoeste Thank you for sharing that you've been having the same issue with your Charge 5 and for confirming that you already tried a few troubleshooting steps.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've provided you with some instructions. In this case, they will let you know how to proceed.
Have a good day.
