07-06-2024 13:47
07-06-2024 13:47
Today I went swimming with my Fitbit Charge 5(less than a meter in depth). I wasn't in the pool for long but my Fitbit just stopped working. The screen went black and it wouldn't charge. I put it in dry rice for couple of days and tried to restart it a few times, but nothing works. The screen is black and it doesn't vibrate. Charge 5 is advertised as a waterproof tracker so is there anything that can be done about it?
07-06-2024 14:11
07-06-2024 14:11
I had a similar thing happen after taking a shower. Several hard resets using the original charging cable and uninstall/reinstall from the Fitbit app fixed the problem.
07-06-2024 17:43
07-06-2024 17:43
I tried to do it, but it didn't work
07-06-2024 23:48
07-06-2024 23:48
I’m having the exact same issue(wrote a post about it) what worked for me in terms of at least getting some type of a response is letting it continuously charge for like three days which allowed me to manually reset it (it vibrated and screen finally turned, synced with my device on but it died again shortly later)
I am hoping that this is all just a hardware issue from Fitbit that is able to be solved by an update from them.
07-07-2024 10:53
07-07-2024 10:53
Did you "Today I went swimming with my Fitbit Charge 5(less than a meter in depth)." or "put it in dry rice for couple of days and tried to restart it a few times"?
I had to wait a few days after getting it wet for my Fitbit to dry out (no rice) before the resetting using the charger to work. You may need to give it more time.
07-07-2024 17:50
07-07-2024 17:50
Hi, I accidentally went in the shower with it. Please see my individual post for more details about the issue I’m having. It seems like this is a really common issue that’s been happening lately.
