11-10-2022
21:59
07:46
DavideFitbit
11-10-2022
21:59
07:46
DavideFitbit
My GPS connects about 1 in 5 times when I run. I’ve re-started several times, I’ve factory re-booted. Clear skies, etc doesn’t seem to make a difference. My charge 4 GPS was much more reliable. Extremely frustrated and looking into other trackers. Btw, I think it was a bad decision to get rid of the floors tracker.as I run a lot of hills and found tgst info helpful. Any suggestions?
11-11-2022
07:45
08:57
11-11-2022
07:45
08:57
Hi, welcome back to the Community forums, @WollyBoy.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5 and the troubleshooting steps that you already tried.
In addition to checking that you are in open sky and moderate trees, please try adjusting how you wear the tracker when you want to use GPS sure the Location in your phone settings is set to Always or All the time for the Fitbit app (if you're using connected GPS). make sure to follow the steps suggested in this article as well.
If you continue to experience the same behavior and your GPS is getting disconnected, make sure the restart procedure you mentioned earlier is the one using the charging cable, instead of the restart available on the device's settings:
I'll be around.
11-11-2022 12:05
11-11-2022 12:05
