My charge 5 screen is stuck on the fit bit app. My phone is an Oppo
My fit bit charge 5 is stuck on the fit bit app screen. My phone is an Oppo
5 REPLIES 5
@Pegjoc Welcome to the Fitbit community!
Sad to hear that your Charge 5 isn't working as expected. As a first step, I'd suggest trying to restart your device by following these instructions:
1.) Connect your Charge 5 to the charging cable which has to be connected to a power source.
2.) Press the button located on the USB plug of the charger 3 times within 8 seconds, holding each press for about 1 second(!).
3.) Wait 10 seconds or until the Fitbit logo appears.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2, Pixel 4a, Pixel 7
I have the same problem. Devicenot restarting, Fitbit logo just keeps on flashing. iPhone13
If restarting doesn't fix your issue, I'd suggest contacting Fitbit support for further assistance:
Fitbit Support Contact
Stefan
Ive tried everything and can't get it to restart. I'm going to take it back where I bought it and ask for a replacement or my money back. Not sure if I want another fit bit. This is the second screen problem I've had with it. Shouldn't have to keep resetting it☹️
Sent from Outlook for Android<>
Tried this. It didn't work. Screen just goes back on withe the logo on the screen
