03-26-2023 14:44
03-26-2023 14:44
If I put it on the charge it looks like is charging normally, it goes all the way till 99% but won’t go to 100, and when I take it off the power source it just won’t turn on. If I try to put it to charge again it starts at 1%. Does anyone have this kind of problems
Best Answer03-26-2023 14:55
03-26-2023 14:55
Mine is not even charging anymore and it is 15 months old.
Best Answer03-26-2023 18:16
03-26-2023 18:16
My original charge 5 quit charging after about 6 months, got a replacement under warranty, that one quit 3 weeks out of warranty. It has no display and wont hold a charge. This is the worst charge I have purchased. They appear to have serious quality issues with the charge
03-27-2023 02:46
03-27-2023 02:46
Hi, @isabelacarla & @HeinoD , I recommend you contact "Customer Support" at your earliest convenience using the chat facility or phone for a prompt response. Before the call note when & where you bought your device.
Cheers
Gr4ndp4 | UK
03-27-2023 06:01
03-27-2023 06:01
My Charge 5 wouldn't hold a charge and died after 14 months. Worst fitbit I have ever owned in many years. It had other problems before it died. I called support and they sent me a discount code for 35% off a new fitbit. I bought another charge 5 and also purchased the 2 year warranty.
03-28-2023 06:25
03-28-2023 06:25
Curious, did they replace the replacement?
Best Answer03-28-2023 06:34
03-28-2023 06:34
I just received the first replacement at 35% off. Working fine so far.
Best Answer03-28-2023 06:53
03-28-2023 06:53
I am having the exact same issue. I received a replacement last July for no display and inability to hold a charge, and my replacement is already doing the exact same thing. I lost my display a few days ago, it started losing its charge yesterday, and now it will not work at all. I am so disappointed.
Best Answer03-28-2023 06:57
03-28-2023 06:57
Hi, @BroSca, welcome to the community, as advised in my earlier post contact Customer Support.
Cheers
Gr4ndp4 | UK
Best Answer03-28-2023 07:01
03-28-2023 07:01
I did. It is out of the 1 year warranty...it is 15 months old, it is terrible. They offered me 35% off. I am not sure if I should purchase another.
Best Answer03-28-2023 07:18
03-28-2023 07:18
Thank you. I contacted them last week and am waiting to hear back.
