09-10-2024 10:04
09-10-2024 10:04
Even the watch awake suddenly it is going to sleep
Best Answer09-10-2024 11:00
09-10-2024 11:00
Hello @Jeevaa
I'm not sure if I understand your issue. Are you noticing that your Charge 5 screen goes dark after a time? If so, that's normal behavior. The display lights up for a short amount of time, then goes dark. This is usually set as the default to help the battery last longer.
You can change the Screen time out length from the Settings menu on your Charge 5:
If this doesn't answer your question, please let us know.
