10-14-2021 03:31 - last edited on 10-14-2021 09:16 by LiliyaFitbit
Is anyone else finding the lack of buttons on the charge 5 very annoying!! I’m ready to throw mine out the window
maybe I’m not tapping properly? Is there any tapping lessons?!!
10-14-2021 03:56
10-14-2021 03:56
Hang on in there! You will get used to it. It's more swipes sideways and up and down.
I've found recently that an easy way to get back to the home screen/clock without setting off another function, is to lightly tap twice at the upper left corner of the screen. I've just had a quick check now and it seems just as effective regardless of which corner.
When you tap in the centre of the screen you're more likely to set an alarm or something by accident...
10-14-2021 08:47
10-14-2021 08:47
@Naihen have you read your user manual or the help guide on using your Charge 5?
Remember the tap is more of a touch.
01-21-2022 07:12
01-21-2022 07:12
The user experience is really awful. I miss my button.
01-21-2022 13:51
01-21-2022 13:51
I find navigation very intuitive and haven't missed the button at all
Best Answer01-21-2022 15:00
01-21-2022 15:00
I agree with @McDoney , i tried the Charge 5 of a friend of mine for a couple of weeks and I'm happily returned to my trusty Charge 4
