09-17-2022
07:21
09:01
DavideFitbit
09-17-2022
07:21
09:01
DavideFitbit
Heart rate not showing when I’m wearing Fitbit
09:00
15:53
09-23-2022
09:00
15:53
Welcome to the Fitbit Community forums, @SunsetRunner.
Thank you for sharing that you've been having this inconvenience with your Charge 5.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've shared some instructions with you. In this case, they will let you know how to proceed.
Have a good day.
Best Answer09-23-2022 18:49
09-23-2022 18:49
Mine works intermittently and support have no solutions. My RHR has not been shown for the last 12 days, before then I got a few a week, now NOTHING!! Useless piece of equipmemt
Best Answer09-24-2022 06:30
09-24-2022 06:30
Having the same problem No heart rate so no sleep stages, etc. Tried reset which got it synching this morning but no heart rate
Best Answer09-24-2022 18:46
09-24-2022 18:46
Best Answer09-24-2022 20:38
09-24-2022 20:38
Can you clarify your role here please. Who has been in contact with support. I was in July on the subject of no RHR data and they had no answers. Has someone else been in touch now?
Best Answer09-24-2022 20:41
09-24-2022 20:41
Best Answer09-24-2022 20:58
09-24-2022 20:58
Best Answer09-24-2022 21:05
09-24-2022 21:05
Best Answer09-24-2022 21:06
09-24-2022 21:06
Best Answer09-24-2022 21:10
09-24-2022 21:10
Best Answer09-25-2022 05:48
09-25-2022 05:48
Didn't work for me. No sensor lights active.
Best Answer09-25-2022 16:44
09-25-2022 16:44
Hasn't worked for me either.
Best Answer09-26-2022 12:57
09-26-2022 12:57
I am so disappointed with the Charge 5. The 4 worked so much better. Heart rate monitor disappears frequently. Syncing only turns it back on sometimes. I looked for more to do in the settings but only found mentions of monitoring if your heart rate is too fast or too slow. And the help I see being offered on this forum is disheartening at best.
Best Answer09-26-2022 15:26
09-26-2022 15:26
Best Answer09-26-2022 16:48
09-26-2022 16:48
Best Answer09-26-2022 16:50
09-26-2022 16:50
Best Answer09-27-2022 06:40
09-27-2022 06:40
Try to let the device drain it's battery fully. I had the same issue (HR sensor stopped working) and nothing worked. Battery died last night, put the charger on this morning, it turned on and it works now.
Best Answer09-27-2022 16:31
09-27-2022 16:31
Best Answer10-14-2022 11:37
10-14-2022 11:37
Hi everyone, thank for your sharing all this information about the issue with the heart rate sensors on Charge 5.
It's good to see that some if you have been able to resolve by turning the heart rate feature Off and then back On. If you're new to this thread or if you're still having this problem, I recommend that you try restarting the device again using the three pulse restart method mentioned here below, instead of the restart option found on the Charge 5 itself:
In addition, you can follow the instructions in this article to improve the accuracy of heart rate information and check the information mentioned here about other factors that could affect your heart rate reading, as this has been useful to other users who have experienced something similar.
If the issue persists, I recommend that you get in touch with the Customer Support team for further assistance with this. They will let you know how to proceed. The best way to get help for this problem is to chat with us online or give us a call. You can click here to get connected.
Thanks again for taking the time to share all your feedback and comments about this.
