11-05-2021
12:26
15:17
DavideFitbit
11-05-2021
12:26
15:17
DavideFitbit
My Charge 5 says device not on wrist,while I am wearing it?? I am getting no heart rate or gaining points.. steps,calories are working everything else seems normal.just blank on heart rate and points
11-06-2021 15:08
11-06-2021 15:08
Oh dear!
Have you tried restarting it? You can do that straight from the Charge 5. Sometimes when something suddenly goes wrong that can help to fix it.
Another thing to do is to check for updates for both the App and the Charge 5, sometimes we miss them and they can be important to fix problems.
Good luck!
11-06-2021 02:29
11-06-2021 02:29
There's a couple of things you could check. Firstly, are you wearing it so that it's making contact with skin? If it's too loose it might not register.
There's some information about it here:
Also please check that your heart rate is turned on on your Charge 5. Scroll down from the Clock Face to Settings, select. Then scroll down to Heart Rate and make sure it's toggled to on. It should show a blue circle on the button (if it's grey, it's off).
Hopefully that should help a bit.
11-06-2021
14:33
15:18
DavideFitbit
11-06-2021
14:33
15:18
DavideFitbit
I am having the same problem. The fixes you said were Of no help. I have had the Charge 5 for a while now and this just happened. It also didn’t register my sleep for last night
Moderator edit: format
11-06-2021 15:08
11-06-2021 15:08
Oh dear!
Good luck!
11-06-2021
15:16
15:39
11-06-2021
15:16
15:39
Hi, and welcome to the Community forums, @SunsetRunner @Mikeysc.
Thank you for sharing that you've been experiencing this inconvenience with your Charge 5.
If you continue to experience the same inconvenience after the steps @Wibby mentioned earlier, I recommend that you try performing a restart and to follow all the other instructions listed in this article to improve the accuracy of heart rate information, this has been useful to other users who have experienced something similar.
Hope this helps, I'll be around.
11-06-2021 15:17
11-06-2021 15:17
Thank you. The restarting the device worked
11-06-2021 15:45
11-06-2021 15:45
I'm so glad!
11-15-2021 15:22
12-06-2021
03:12
16:46
DavideFitbit
12-06-2021
03:12
16:46
DavideFitbit
I have the same problem. when I rest it works for a while and then it goes blank again. this has happened three times since I start using Charge 5. I only got it a week ago.
12-14-2021
13:14
16:45
DavideFitbit
12-14-2021
13:14
16:45
DavideFitbit
I had the same problem twice with my Charge 5 within a week. Restarting the device was a solution. I hope there will be a software update soon.
12-18-2021
16:45
15:39
12-18-2021
16:45
15:39
Hi, thank you for sharing that you've been experiencing the same inconvenience with your Charge 5, @NareshSathy.
I've been informed that you already contacted the Customer Support team for further assistance with this. In this case, they will let you know how to proceed.
Welcome to the Community forums, @KoenP. Thank you for sharing that you were able to resolve it after the restart procedure. Let me know if you continue to experience the same behavior.
Have a good day.
12-19-2021 01:05
12-19-2021 01:05
12-23-2021
08:52
15:38
12-23-2021
08:52
15:38
@KoenP Thank you for your reply.
In this case you're referring to the process of syncing your data with your account (steps, calories, floors), correct? Or let me know if you referring only to the heart rate information that isn't syncing properly.
I'll be around.
06-05-2022 16:48
06-05-2022 16:48
I have the problem as well... I've had the unit only for a few days, and it is happening every day.
06-06-2022 08:13 - edited 06-07-2022 10:26
@DavideFitbit I too am having this issue along with several other issues. I’ve restarted my Fitbit multiple times and I have verified that the option to track HR is turned on. Nothing is fixing it.
06-06-2022 15:19
06-06-2022 15:19
I had been having the same problem plus no sleep tracking. I was able to return mine because the 45 days wasn't up yet. I packaged up my charger5 plus the charger and band in the original box and packaging according to instructions. HEADS UP! I get the replacement and they only sent the watch face, no band or charger. Support said that's all they usually replace. No one told me to just send just the watch face back when I was emailed the shipping label. So I am trying to straighten that out now. Customer support is not good at all.
06-15-2022
10:09
15:13
06-15-2022
10:09
15:13
Hi, and welcome to any new users in the Community, @RodMontreal @big24fanz @cmomsied.
Thank you for all your replies and for confirming that you are still experiencing this issue with your heart rate and that you already tried the suggested troubleshooting steps. In this case, if you already tried the recommendations mentioned here earlier and your device is still not recording your heart rate, I do recommend that you continue the communication with the Customer Support team so they can let you know how to proceed of what are the options available for you. I appreciate all the feedback and comments provided so far about this.
The best way to get help for this problem is to chat with us online or give us a call. You can click here to get connected.
See you around.
