05-08-2024 19:55
05-08-2024 19:55
My Charge 5 no longer records heart rate zones on the map of either when I’m walking or cycling. It used to. Still buzzes when I enter cardio or peak, just doesn’t record it.
why?
05-09-2024 03:35
05-09-2024 03:35
@Last_Jedi You are describing an app issue. Do you use an Android or iPhone? What version of the app do you have? Can you include a screenshot that shows the problem?
Laurie | Maryland
05-09-2024 07:31
05-09-2024 07:31
Iphone. Worked last week on both walks and cycling. Just started about the same time as the sleep portion went to hell, so I figured this was another "update" from Google. The Fitbit shows 80% battery, so it's not a power issue. Oh well.....
