03-30-2022
08:14
06:32
DavideFitbit
03-30-2022
08:14
06:32
DavideFitbit
No sleep score. Device tells me to wear to bed - but I do!
Best Answer03-31-2022 06:31
03-31-2022 06:31
Welcome to the Fitbit Community forums, @bernietmke .
Thank you for sharing all this information about the problem that you've been having with your Charge 5.
Keep in mind that you must see sleep stages in order to see a sleep score. There are a few scenarios where you might see your sleep pattern (which shows your time asleep, restless, and awake) instead of sleep stages:
If you see sleep stages but don’t see a sleep score, please note that it may take a few minutes for your sleep score to appear. In addition, for better results please try to let the device detect that you're awake or asleep by itself rather than doing it manually and make sure to keep the Fitbit app and the devices' firmware updated to the latest version available.
The Charge 5 may need some days to collect some information (particularly regarding to heart rate) and provide sleep score, sleep stages and other data. Make sure that you've also tried the restart procedure described here and check if you continue to experience the same problem. In case the problem is related to the Fitbit app, please try the following as well:
I'll be around.
Best Answer03-31-2022 07:00
03-31-2022 07:00
I have the same issue. It's very intermittent. Some days it will track sleep, others not. It also doesn't track my heart rate all the time. I'm calling support now.
Best Answer04-08-2022 10:50
04-08-2022 10:50
Hi, thank you for sharing that you've been having the same problem with your Charge 5 and for confirming that you already tried the troubleshooting steps suggested earlier, @tabbymom38.
I've been informed that you already contacted the Customer Support team for further assistance with this. In this case, they will let you know how to proceed.
Have a good day.
