03-02-2025
21:18
11:48
AndreaFitbit
03-02-2025
21:18
11:48
AndreaFitbit
stress management score has stopped working on the 27th Feb, there are a lot of posts in the community help options
Moderator Edit: Clarified subject.
03-03-2025 11:07
03-03-2025 11:07
Hello @leanne275
As you noted, there are multiple reports about this issue. Several of us have submitted the issue for escalation so the team is aware of the problem.
We are advising users to report the issue using the Feedback option in the Fitbit app:
Although it's likely that you won't receive a response, the team receives & reviews the feedback reports.
The Moderators usually pick a thread to acknowledge the issue and will use that thread to post updates. When I find which thread they're using, I'll report back with a link so you can follow the thread.
03-05-2025 14:11
03-05-2025 14:11
Hello @leanne275
I'm seeing my stress management score in the app today (05 Mar 2025). Please let us know you are seeing your score in the app.
Best Answer03-05-2025 14:19
03-05-2025 14:19
No, I have no stress management score still
Best Answer03-05-2025 16:35 - edited 03-05-2025 16:37
Hello @leanne275
Thank you for confirming you're still not seeing your stress management score in the app.
If you're an Android user, please post to this thread (<-- click link) saying that you still don't have a score. Also provide which Fitbit you use - Charge 5 in your case, the version of your Fitbit app, & what phone you use for the app. The Moderator on that thread will be able to send your information to the team so they can continue to work on fixing the problem.
03-06-2025 09:57
03-06-2025 09:57
I have the iPhone and my Stress Managment Score also stopped working the same day as yours. My app is updated, I have turned on/off phone, I have deleted the app/redownloaded it, I have restarted my tracker (I have the Luxe). All requirements are also met - I wear it 24 hours a day, walk well over the necessary steps the score requires, and sleep with my tracker as well. I have never had an issue with Stress Managment before - and all of a sudden it just doesn’t generate a score anymore.
Best Answer03-06-2025 15:05 - edited 03-06-2025 15:33
Hello @Activelyalexand
Please submit the issue using the Feedback option in the Fitbit app using the steps I provided in an earlier post.
I checked the iOS app forum and don't see a similar thread there about the missing stress management score. You can post to the thread in the Android forum as the Moderator said that she would provide updates there.
Update: According to the Moderator posts in the above linked thread and this one (<-- click link), the issue has been fixed. If you still don't see your stress management score tomorrow, please post in one of the 2 threads, tag the Moderator, and let them know that you still have the issue.
Best Answer03-06-2025 17:21
03-06-2025 17:21
I did submit the feedback earlier today, after I read your post. Coincidentally, my stress management score appeared moments later!
03-06-2025 17:27
03-06-2025 17:27
Hi Everyone, thanks for your comments regarding this situation with the Stress Management score.
We received the update from our team and the issue should be resolved by now.
Please restart your phone and give it a try .
Please confirm here if it got solved for you or if you are still encountering difficulties.
03-07-2025 13:47
03-07-2025 13:47
Hello @leanne275
Did you get your stress management score this morning (07 Mar 2025)? Please let us know.
Best Answer03-07-2025 15:02
03-07-2025 15:02
yes, finally! Thank you
03-07-2025 19:43
03-07-2025 19:43
Hi Everybody.
Thank you for being aware of the situation.
If some of you have not yet received the Stress Management score please make sure of the following:
03-08-2025 11:26
03-08-2025 11:26
Hi @leanne275
Thanks for confirming that you're getting your stress management score again. It looks like the problem has been fixed.
