03-04-2024 10:06
03-04-2024 10:06
I have restarted my Charge 5 and checked settings. Do not disturb is not on. I don't get my ten to eleven AM movement reminder. Any help?
03-05-2024 10:04
03-05-2024 10:04
I have been having the same problem!
03-05-2024 14:25 - edited 03-05-2024 14:26
Hello @WUpdegrave & @janicekay63
Every now & then, I won't get the reminder to move at 10 minutes to the hour. When this happens, I:
Usually, this is enough to get the Charge 5 "unstuck" and Reminders to move to work again.
BTW, I noticed that I didn't get a reminder to move in the afternoon although it was working in the morning. I did the process that I described above. So far, the reminders to move are working today. Hopefully, you will have the same success.
03-09-2024 13:50
03-09-2024 13:50
Tried this, didn't work. Any other suggestions?
03-10-2024 12:07
03-10-2024 12:07
Hello @Gumby51
I don't have another suggestion to try. The process I described has worked for me so far. That said, I have noticed that it can take more than 1 attempt to get the Charge 5 "unstuck". It might be worth trying the process at least 1 more time.
03-20-2024 13:07
03-20-2024 13:07
03-20-2024 14:14
03-20-2024 14:14
For the screen wake issue, try this:
From the main screen, swipe down to Screen Wake, it should be set to Auto. If it says Manual, tap the screen to toggle the setting.
Gary D.| Feeding Hills, MA MBG PE
Charge HR, Charge 2, Charge 3, Inspire 2, Charge 4, Charge 5, Pixel Watch 2, Pixel Watch 3
03-21-2024 07:51
03-21-2024 07:51
These reminders have never been consistent for me. I honestly think the Charge 5 doesn't have sufficient memory to keep this feature active at all times. Or maybe mine is just buggy?
