10-15-2023
11:16
14:17
10-15-2023
11:16
14:17
I've tried absolutely everything mentioned and I've read lots. I've updated the app, turned off/on bluetooth to everything, double/triple checked all settings on phone and fitbit app, removed the app from my phone & reinstalled but still don't get notifications of text & calls. I used to get them no problem, didn't change anything but it just stopped working. It's the only reason I wear this device. Is there possibly any other suggestions or is the device now scrap?
Hi there, @Freddie58. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Charge 5 before reaching out. I understand how you must be feeling.
As a first approach, I'd recommend checking if your Charge 5 is in sleep mode. When sleep mode is on:
If the above doesn't describe your issue, please verify you tried the steps below in the order listed:
With the steps above, what I want you to do is to pair your Charge 5 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer"Unpair other Bluetooth devices that you may also have paired to your phone's Bluetooth settings." Are you mad? Why don't you suggest he get a new phone and a new Fitbit. Move no settings or data to the new phone. Open a new Fitbit account. Then simply start your life over again. Perhaps removing all electronic devices for a 5mi/8km radius would help as well, your neighbors won't mind.
I know you opened a can and found this reply. Don't go back to that shelf of can goods again. I think those cans have gone bad.
