09-15-2022 13:29
09-15-2022 13:29
My charge5 was paired with my Samsung tablet ut when it switched off because of battery flat I have not been able to sync I unpaired it and then tried to pair it, thinking it would solve it but now it won't pair at all. Any suggestions?
09-17-2022 06:22
09-17-2022 06:22
Yes, most BT devices will only connect to one server at a time.
Glad you got it figured out.
Please remember, that the fitbit app, not the user, managed the BT pairing.
Now you should mark your response as the best answer.
09-17-2022 05:03
09-17-2022 05:03
Not sure what you mean by unpsir @Eiragwyn
To unpair means to remove from the tablets Bluetooth.
Once unpaired, open the fitbit app, the app should ask permission to pair the tracker. Pairing can not be done by the user.
If the tracker doesn't sync please see
One tip, that is not mentioned, is to clear the Fitbit Cache, and once I had to clear the Bluetooth cache.
Removing the tracker from the app, will not unpair the tracker from the phone, it only removes the tracker from your fitbit account. . You will need to unpair the tracker.
Now you need to setup a tracker, with the fitbit app, and you already know that the app can not talk to the tracker.
09-17-2022 06:17
09-17-2022 06:17
09-17-2022 06:22
09-17-2022 06:22
