Putting 2 trackers on one cell phone?
I have a Charge 2 and it works , the wife is using it. Just got a Charge 5 (it's charging up right now)
How do you put 2 trackers on 1 cell phone? We only have 1 for the 2 of us.
Do you need 2 apps or just one?
tony14
5 REPLIES 5
As an iPhone user, I can tell you that you can only download one copy of an app.  I’m pretty sure it’s true for Android.  Each user must have their own account to their own email.  One user must log out of their account and the other can login with their account to sync.  Can get tedious.
Laurie | Maryland
@tony14 If your're using a smartphone running Android, it's depending on the Android version. Sometimes you can enable Multi User mode in the settings. Then each user has her/his own private space where she/he can install apps. So you could run two instances of the Fitbit App.
Stefan
Charge, Charge HR, Blaze, Versa, Versa 2, Charge 5, Charge 6, Versa 4, Aria, Aria 2, Pixel 4a, Pixel 7
Thank you for the reply's
@Talahthas  I have looked but can't find what you are taking about.
For a cell phone I have a Samsung A03s it looks like I can't do this may have to return the Fitbit.
@tony14 I'm not sure whether or not this will be working on a Samsung A series as well, but please try to check for Settings >> Device >> Users:
Stefan
I have double checked and can not find the device tab.
I'm going to take it back today thanks for trying.
