I don't think so. If you're swiping left from the clock face, it's only 2 swipes...if you're swiping right, it's 4.
If you mean scrolling through the 6 exercise shortcuts listed on your tracker, you could reorder them in the App, which will change the order you see them on your Charge 5. If you don't use 6, you could erase some. I have mine set so that the 2 I use all the time are first and second and that seems fine to me.
I couldn't work out a great way to reorder the shortcuts on the App, so I just deleted them and then added them in the order I wanted them.
I hope that helps a bit.
