07-17-2022 23:22
07-17-2022 23:22
After being Gully satisfied with my charge 5 it suddenly changed its behaviour. The red light on the back shines always and the battery runs completely down in less than six hours.
every advice from this forum doesn t help
07-18-2022 02:24
07-18-2022 02:24
Hi, @Mutabor, welcome to the community, is this a charging issue? Check the State of Charge by syncing your phone app and noting the SOC in the icon in the top right corner of the "Today" screen. You may find Why isn't my Fitbit device's battery charging? of interest. Generally, we do not see many charging issues with the "Charge 5" on the forum but on other devices, we often recommend cleaning the back (Where the contacts are). Fitbit Wear & Care provides advice, I use rubbing alcohol with a cotton swab, and while I have the swab in hand I usually clean my phone and mouse as well. Try restarting your Charge 5 Troubleshooting provides guidance.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
07-18-2022 07:34
07-18-2022 07:34
Thanks to the UK for your prompt reply. No, it s not a charging issue - charging works quite well.
I think the red spotlight on the back, which runs constantly is consuming all the energy.
If nobody has a new idea I ll geht convinced to drop this device.
07-18-2022 07:42
07-18-2022 07:42
Hi, @Mutabor, I think your best way forward is to talk to "Customer Support" using the Chat facility or phone for a prompt response.
Cheers
Gr4ndp4 | UK
08-16-2022 11:48
08-16-2022 11:48
Tried everything. Red light still on.
Only purchased in January 2022
probably go to another brand
08-17-2022 01:37
08-17-2022 01:37
Hi, @TRXNMN , welcome to the community. Talk to "Customer Support" using the chat facility or phone for a prompt response. Note this article Fitbit Charge 5 owners can sync again after an outage blocked them on Tuesday - The Verge your problem may be a result of an outage.
I hope this helps.
Cheers
Gr4ndp4 | UK
