03-29-2023
11:45
17:25
AndreaFitbit
03-29-2023
11:45
17:25
AndreaFitbit
Not sure if the ecg on the watch has been removed. I used to be able to do a 30sec reading on the watch itself but now the option is no longer there. I ask because for some reason im getting afib reports on the watch telling me to see a dr but no notifications on the phone to show.
Moderator edit: format.
Best Answer03-29-2023 14:51
03-29-2023 14:51
Hi @Woodey12 afib does not use the ECG.
Also have you looked under the tracker available apps (in the fitbit app) the option to install, depending on your location, should be there.
As for AFIB. open the fitbit app.
Tap Discover (found at the bottom of the screen)
Tap Assessment and Reports
Tap Irregular Rhythm Notifications
Tap View Notifications.
03-29-2023 14:51
Best Answer03-30-2023 05:33
03-30-2023 05:33
Hi Rich_Laue, thanks for your answer. I have looked at all the options that you suggested and I still don't have the options that I have had before. The option that is no longer on my watch was the one with a heart picture and said 30 seconds. The option has gone from the watch and I have looked at all the available apps and on the phone and what's installed. As for the afib I have viewed the notifications on the phone but it says I don't have any even though the watch detected afib and warned me. Thanks again.
