09-27-2021 10:47
09-27-2021 10:47
Best Answer09-27-2021 18:03 - edited 09-27-2021 18:05
I switched to Active Zone Minutes as my Main Goal, but the step count does not go away.
I went for a bike ride, used the manual Bike Exercise to track the exercise/movement, and it still added Steps. That is crazy incorrect. Walking and Cycling are very different things.
For a Fitness Tracker it really should count Movement. Counting step diminishes the Fitbit's capability and turns it into a glorified Step Tracker.
Best Answer09-27-2021 13:11
09-27-2021 13:11
Hi @_FitBob_ you can see your choices here - click to read.
Best Answer09-27-2021 13:46
09-27-2021 13:46
Movement or Active Minutes is not available as an option under Main Goal.
There is Calories, but that's tracking a potential side effect of movement not actual movement. I can burn calories while sleeping and not moving.
09-27-2021 14:11
09-27-2021 14:11
You can make suggestions here - https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features
