07-18-2022 12:47
07-18-2022 12:47
I locked my device to swim yesterday as I had on 2 prior occasions. When I went to unlock it, the screen was blank, no amount of double taps unlocked it and this morning I received an email notification that the battery is low. It has been in the recharger today with no change. Pressing the button on the recharge cable has no effect.
Help?
07-18-2022 13:22
07-18-2022 13:22
There are a whole lot of reason why it wouldn't charge :
*Have you checked the charging contacts, they might be dirty .
*It might be wet, so dry it properly or the USB port or charger is faulty .. Hope you resolve your issue soon .
Best Answer07-18-2022 14:50
07-18-2022 14:50
Best Answer07-18-2022 18:26
07-18-2022 18:26
Same issue. Currently trying the cleaning and drying recommendation. But not holding my breath since it didn't vibrate when connecting to charger.
Best Answer07-19-2022 10:41
07-19-2022 10:41
