06-13-2022 05:26
06-13-2022 05:26
Any one else figure out how to turn on the screen by rotating your wrist? It got switched to manual and won't let me switch it back to automatic....
Best Answer06-13-2022 06:16
06-13-2022 06:16
Hello @Simon-Ash
Do you have Sleep Mode on or DND by mistake? If so, tap to turn them off and then you should be able to change Screen Wake to auto again.
I hope that helps.
Best Answer06-13-2022 06:07
06-13-2022 06:07
@Simon-Ash From the home screen swipe down until you see Screen Wake tab. Tap the tab to switch between manual and automatic.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
Best Answer06-13-2022 06:10
06-13-2022 06:10
I have tried and it doesn't switch. It's almost as if the feature is locked.
06-13-2022 06:16
06-13-2022 06:16
Hello @Simon-Ash
I hope that helps.
Best Answer06-13-2022 06:56
06-13-2022 06:56
Yes! Thank you! That fixed it.
