Any one else figure out how to turn on the screen by rotating your wrist? It got switched to manual and won't let me switch it back to automatic....
Best AnswerHello @Simon-Ash
Do you have Sleep Mode on or DND by mistake? If so, tap to turn them off and then you should be able to change Screen Wake to auto again.
I hope that helps.
@Simon-Ash From the home screen swipe down until you see Screen Wake tab. Tap the tab to switch between manual and automatic.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
I hope that helps.
