05-03-2022
15:12
07:32
DavideFitbit
05-03-2022
15:12
07:32
DavideFitbit
Hi
my Fitbit went black and now won’t turn back on. I tried the “press the button three times” and nothing. I also tried changing the watch face and nothing. Someone had suggested unpairing and re-pairing but that doesn’t work because I can’t see the numbers on the screen. Help!!
Thanks
Melissa
05-03-2022 18:04
05-03-2022 18:04
Same. Constant same issues since I purchased it. Put it back on the charger and then it’s on again and within an hour or two screen goes black. I just
got off the phone with support and he had me again put it on the charger, and reset the device under settings on the watch. I don’t have much faith that will fix it
Best Answer05-03-2022 18:06
05-03-2022 18:06
Best Answer05-03-2022 18:24
05-03-2022 18:24
You might want to contact Fitbit Support at the Get Support at the bottom of the page.
Best Answer05-03-2022 18:28
05-03-2022 18:28
I did. They had me restart the device. I don’t have much hope for that fix. Will see.
07:32
08:25
05-04-2022
07:32
08:25
Hi, and welcome to the new users in the Community forums, @mlx415 @Alimlclm.
Thank you for sharing that you've having this inconvenience with your Charge 5 device and that you already tried a few troubleshooting steps.
If you already tried to complete the 3 pulse restart procedure and you continue to experience the same problem, please try these additional steps that have been useful for other users:
If the issue persists, I recommend that you get in touch with the Customer Support team for further assistance with this.The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Hope this helps, I'll be around.
Best Answer05-04-2022 10:54
05-04-2022 10:54
Yes. I’ve tried all of that. It works for limited amount of time and then goes black. Called last night again, went through all of that, went black during the night. Did it again, went black again mid workout a half hour after I restarted it. Chatted with support and had it back on again after a restart only to have jt go off midday again. I’ll be chatting/calling when I get home for the 4th time. I can get it on, but it doesn’t stay on.
11:42
08:25
05-06-2022
11:42
08:25
@Alimlclm Thank you for sharing this update. I'm sorry to see that you're still experiencing this problem.
In this case, I recommend that you continue the communication with the Support team to let them of the steps that you already tried and that you continue to experience the same problem. They have specialized tools and will let you know what are the options available for you.
Thank again for sharing all your feedback and comments about this.
Have a good day.
