07-01-2022 12:22
07-01-2022 12:22
How do a I get a single number cardio fitness score, instead of a range?
I've got a charge 5 with GPS enabled. I"ve done several runs over 12 minutes within the last month. I've done 6 runs this week. All runs were using exercise mode. After the run, I see the map and the distance.
What is the algorithm for showing single digit score?
Is there anything else I need to do?
07-04-2022 11:33
07-04-2022 11:33
I have the exact same problem. I had a cardio fitness score with my Charge 4. Once I switched to the Charge 5 it became a range. Doesn’t seem to matter how many gps runs you record - it is still just a range that doesn’t seem to change.
Best Answer07-13-2022 21:50
07-13-2022 21:50
Wonder why a moderator hasn’t provided any “support” for this…
07-14-2022 09:02
07-14-2022 09:02
Me to.
Do you have a single digit cardio score?
Someone told me they stopped providing a single score, but I can't find that documented anywhere. Fitbit documentation still says you will get a single score after a few runs exceeding 10 minutes. I'm doing more than 20 minutes everyday on flat ground.
I wish they would publish the algorithm, or at least a rough approximation. Perhaps I'm not doing everything I need to.
Best Answer07-15-2022 06:14
07-15-2022 06:14
I had a single digit cardio fitness score for over a year. Then it turned into a range and continued to drop to levels that are not accurate. I run marathons but it shows my levels as low 30s and “fair” for women my age.
Best Answer10-23-2022 05:43
10-23-2022 05:43
An update.
After working with tech support that told me the fitbit was defective and sent a replace. They never explained what the problem was or gave a technical explanation. They wouldn't tell me what data was insufficient or missing. I'm skeptical.
It's been a few weeks and I still don't have a single digit score. I've only had 4 runs since I got the replacement, so I'll give it a little more time. I've been busy, but I'll get 5 runs next week.
I am very disappointed with fitbit support.
