01-18-2025 03:31
01-18-2025 03:31
Hello
In sleep monitoring I find sometimes that the entire period of the night is not included in the trace but a part is excluded from the graph and is reported as "other sleep". Why does this happen? How do I invite him to make sure that everything is tracked within the graph with the sleep phases?
Best Answer01-18-2025 05:57
01-18-2025 05:57
Hello @MatteoGhinassi and welcome to the Community. Your "other sleep" log says that you woke up at 00:24 and your main sleep log says that you fell asleep at 01:57. You were either awake or your Fitbit measured data that said you were awake. That gap is over 90 minutes and is long enough to split your sleep into two sessions.
Laurie | Maryland
01-19-2025 03:45
01-19-2025 03:45
Hi! LZeeW Thanks for your reply!
The monitoring in my opinion does not work: it reports for example that last night I went to bed at 00.30 AND that I woke up from 1.31 to 2.34 ... That's not true!
I slept all night without waking up.
How can I improve monitoring?
Do you think it is faulty on the hardware side or do I need TO try to fix the pameters of the app??
