02-14-2024 08:56
02-14-2024 08:56
My Charge 5 splits my sleep tracking into 2 sessions many nights with several hours between sessions. I know I wasn’t awake during those times. Has anyone else experienced this problem?
Best Answer02-14-2024 10:06
02-14-2024 10:06
Hi, @Gerristewart, welcome to the community, may I draw your attention to How do I track my sleep with my Fitbit device? - Fitbit Help Center This allows you to review the process and how you interact with your Charge 5.
Let us know how you get on, if you are still stuck please provide more information.
Cheers
Gr4ndp4 | UK
02-14-2024 10:06
Cheers
Gr4ndp4 | UK
Best Answer02-14-2024 14:26
02-14-2024 14:26
I’ve used the information from the hyperlink you provided. I still have the problem. I’m attaching a screenshot of my sleep tracking. As you can see, my sleep was split into 2 sessions on Sunday night and last night. I was not awake during the gaps in tracking. Any suggestions?
Best Answer02-14-2024 16:03 - edited 02-14-2024 16:07
Hello @Gerristewart
Every now & then, my tracked sleep gets divided into 2 logs. I haven't figured out what causes this. Although it's a bit annoying, the good news is that we can edit the tracked sleep in the Fitbit app to make it a single log. To do this:
It's been my experience that it can take some time - an hour or so - for the Fitbit app to update the sleep log, including length of sleep, score, and stages. BTW, you can use the same steps to fix your sleep start or wake up time, which also happens to me every now & then
Don't worry about deleting a sleep log and whether that's going to mess up your sleep data. It took me a while to realize that deleting a sleep log only deletes the time frame and not the tracked data, which is still on your Fitbit.
Don't wait too long to fix your sleep logs. Your Charge 5 is supposed to keep tracked data for about 7 days. After that, there isn't a way to recover the data if it doesn't get synced with the app.
If you have any further questions, please let us know.
