06-27-2022 05:00
06-27-2022 05:00
My Charge 5 would not come out of Swim Lock mode (yes, I was hitting the screen, not just tapping firmly) so I let the battery discharge completely. When I connected it to the charger after 4 days, the logo screen came up and it's stuck there. Pressing the button on the charger to reset it doesn't do anything. It will not sync in this state either.
06-27-2022 07:35
06-27-2022 07:35
Hello @Jsgoings and welcome to the Community. Just to clarify one thing. You need to press the button 3 times, pausing for 1 second between presses, to restart a Charge 5. You were very clear about trying to turn off the water lock. If you followed the restart correctly, and tour device is still frozen, please contact Support.
Laurie | Maryland
06-27-2022 18:54
06-27-2022 18:54
I'm having a similar problem.... when you say press the button 3 times... what button?
06-28-2022 03:58
06-28-2022 03:58
Hello @Swhitley and welcome to the Community. The button is in the USB end of the charging cable.
Laurie | Maryland
