11-13-2022
18:37
10:09
DavideFitbit
11-13-2022
18:37
10:09
DavideFitbit
Won't re- pair to sync; app reports incorrect data for previous days; data subsets (heart, exercise and ex intensity) have disappeared from phone; Fitbit froze and then 'reset' to crazy time 17 hours and 14 min off. Have tried all 'solutions' but no result except now I have this crazy time. Have established that it is NOT my phone's Bluetooth that is the problem.
10:08
06:33
11-30-2022
10:08
06:33
Hi, welcome back to the Community forums, @JustWalk6.
I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5.
If you haven't done so already, please try the following steps that have been useful for other users:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available. In case there a problem related to the app not showing you the correct information, please try the following steps:
Hope this helps, I'll be around.
