05-03-2023 23:04
05-03-2023 23:04
Seems to be a lot of posts about water damage. I swam fine with it in the late summer / fall. But the last two weeks when I do the peleton bike my arms sweat so much it seems to cause water damage. I see water droplets at the back inside where the sensor is. Now after a week of struggling to reset it constantly the sensor no longer works and my fitbit can only be used to tell the time and not track anything. Can this be repaired or am I out of luck and have to buy a new one? I've had nothing but issues with the Charge 5.
05-04-2023 02:54 - edited 05-04-2023 02:54
Welcome to the Fitbit community, @Leetz!
Sad to hear that you're having issues with your Charge 5. I'd suggest to contact Fitbit support asap to see what they can do for you:
You might also have a closer look here to keep your device in good condition in the future (Keep it Clean and Dry):
