10-25-2021
11:00
10:17
LizzyFitbit
10-25-2021
11:00
10:17
LizzyFitbit
Has anyone gotten the Hook and Loop band and tried swimming or showering with it? I am wondering how quickly it dries, etc. before purchasing one.
Best Answer10-25-2021 11:55
10-25-2021 11:55
I have this type of band for other Fitbit devices. (Love them!) Since they are woven, I do not recommend swimming or or showering with it. I got one of mine wet once and it took a long time to dry. Maybe someone else here can comment on their experience.
10-25-2021 12:41
10-25-2021 12:41
How also have folks attached it? I have seen it both ways. With the shorter clasp on both the top and bottom.
Best Answer10-25-2021 14:48
10-25-2021 14:48
I bought it from fitbit and I'd say it'd dry relatively fast if you soak it with a dry towel. I ended up returning mine though as the velcro on it worn out super fast.The band ends up coming off really easily in just two weeks of usage. Would not recommend getting it.
Best Answer11-01-2021 08:27
11-01-2021 08:27
Hello again, @Harrisburger - I ordered that band and it came in. I really like it. It’s very comfortable but …
I still like it. It’s probably the most comfortable band I’ve ever worn.
01-18-2022 11:25
01-18-2022 11:25
Not so happy with the unused velcro showing also. If one is lucky with wrist size that could be avoided maybe. With my wrist size of 16,9 cm the large band would have been perfect I think. Went for the smaller band instead. Also a cool feature of this band since so slim in design is that when you turn the wrist to watch the device, it sneaks out way more easily than with any other Fitbit band I've used while wearing long sleeves, wind jackets, etc.
04-28-2022 21:31
04-28-2022 21:31
Bit late but if anyone sees this hopefully it will help! I am on my second hook and look strap (the second one sent for free by Fitbit after a complaint) and the Velcro doesn’t last very long at all. I’ve only had my 2nd strap 2 weeks and I can already feel it is not sticking as well.
I don’t get my band wet, don’t wear it for showering and I change to the silicone band for swimming.
Shame they don’t do the regular woven band like on the sense. No idea why they only sell certain bands for certain watches, it’s a ridiculous idea.
04-30-2022 04:44
04-30-2022 04:44
I got mine from Fitbit for free since the originally purchased Infinity band had this tendency to gnaw my skin due to its design I think. I've been super happy with theHook and Loop replacement band, but now after 4-5 months of use, it has kind of deteriorated somehow (see picture). No problem with the velcro not holding though. And I wore it 24/7 in a pretty rough manual labor environment.
