03-25-2022
11:17
07:25
DavideFitbit
03-25-2022
11:17
07:25
DavideFitbit
It's 1115 AM in Arizona. We're on MDT, clocks the same as California.
My Charge 5 says it's 615 PM on the same day.
Checked my account, it is on Arizona MDT time.
I restarted my FitBit - no change
I plugged it into the charger - no change
Any other ideas on how to fix this ASAP?
03-26-2022
07:24
07:46
03-26-2022
07:24
07:46
Hi, I appreciate all the details that you've provided about this inconvenience with your Charge 5 and the troubleshooting steps that you already tried, @moriahpulver.
In addition to the restart procedure that you already tried, please try the following steps as well:
Hope this helps, I'll be around.
Best AnswerThank you for this info. I will keep it in mind if this happens again.
Late last night, I noticed that my FitBit wasn't syncing. It does this sometimes...so I turned off BluTooth and turned it back on. Then I force quit the app. When I reopened the app, I felt a vibration on my wrist...voila! the time had corrected itself!
