Too short alarm on Charge 5
ANSWERED
Is there a way to expand the duration of the vibration of an alarm? Sometimes I don’t wake up before it goes into snooze mode.
1 BEST ANSWER
Accepted Solutions
Hi @OlavD  sorry, there is no way to make the alarm last longer. Maybe you can set an alarm for a few minutes after the first one, so you get one alarm after the other.
Stepping in the U.S.A. since September 2013. Android 14
3 REPLIES 3
Good idea - will try setting several alarms.
Br,
@OlavD it always worked for me. If you vary them slightly each day, your body won't get used to them and it should wake you up.
