04-16-2022 07:59
04-16-2022 07:59
Is there a way to turn of bluetooth? The right functionality would be the ability to toggle bluetooth but retain data logging. Then the user could sync when BT is enabled.
Is this possible with the Charge 5?
04-16-2022 11:13 - edited 04-22-2022 06:53
Hi, welcome to the Fitbit Community forums, @decadeca.
Thank you for your inquiry about the Bluetooth on the Charge 5 and other Fitbit devices.
Unfortunately this option (manually turning off Bluetooth) is not yet available on Fitbit watches and devices at the moment.
This idea was previously posted in the Feature Suggestions board of the community, this section is regularly reviewed by the team of developers for possible updates in the future. I recommend that you vote for these ideas posted in the forums and to add your comments as well, this is always helpful for the team to continue to track popularity and demand over time:
Keep in mind that the emission of the Bluetooth from Fitbit devices is too low to cause harmful effects on the body.
See you around.
04-16-2022 18:53
04-16-2022 18:53
Perhaps
04-16-2022 19:16
04-16-2022 19:16
You can read more on the FCC websight.
04-22-2022 06:57
04-22-2022 06:57
Thanks, @Rich_Laue @USCTrojans!
