10-13-2022
20:05
16:40
AndreaFitbit
10-13-2022
20:05
16:40
AndreaFitbit
When I try to set up I get the message that my e mail address has been previously used for a fitbit. This is not correct as I have not used the address before.
How do I get Fitbit to sort this out so that I can use my new charge 5
Best AnswerHello @DJR123 and welcome to the Community. I apologize if I'm misreading your post. It sounds like you are trying to set up a new account. That's the only reason I can think of for that message. I looked at your profile and can see that you joined Fitbit in April 2022, so you already have a Fitbit account. Did you use that email in April? If so, you need to log in to that account. You will get a prompt to change your password if you forgot it or don't have it saved on your phone. Once you log in to that account, tap on your profile avatar > select the +Set Up a Device option and follow the prompts.
Laurie | Maryland
