10-31-2022
08:33
08:14
DavideFitbit
10-31-2022
08:33
08:14
DavideFitbit
Best Answer11-01-2022 08:14
11-01-2022 08:14
Hi, I appreciate all the information that you've shared about the difficulty you're experiencing with your Charge 5 @SBejai.
If you haven't done so already, please try the following steps that have been useful for other users as well:
In addition, I recommend that you try restarting the device using the three pulse restart method:
If you're still having any issues, let me know if you already tried all the steps listed here to resolve syncing problems, and make sure to check the compatibility requirements listed here and to keep the Fitbit app updated to the latest version available.
I'll be around.
11-01-2022 08:14
11-01-2022 08:14
I'll be around.
11-01-2022 11:28
11-01-2022 11:28
Force quit the Fitbit app and then opening the app is mostly what is needed in my experience. I must do it on a weekly basis, but it is not a big deal once I get used to the procedure.
11-01-2022 19:30
11-01-2022 19:30
It took me over an hour to do mine! I had to reset the device and restart the Bluetooth umpteenth times until it finally connected! I even reset my Data Connection to try to get a better signal thinking maybe that was the issue.
I had to reconnect my device because it was deducting steps! I lost all my steps for today. Every time it synced with the App it would deduct my steps and my delete workout! This is the second time in two weeks that the App has done this to me!
11-23-2022 06:04
11-23-2022 06:04
@jfe @FLCRICKET Thanks for taking the time to share your feedback and experience with this.
It's great to know that your device is now syncing. Let me know in case you continue to experience the same issues after all the steps suggested earlier.
Thanks again for all the comments and feedback provided about this.
10:11
09:05
DavideFitbit
11-23-2022
10:11
09:05
DavideFitbit
I've been having problems with my Charge 5 not charging and dead battery. Tried the steps above and nothings working.
Moderator edit: format
11-30-2022
22:49
09:04
DavideFitbit
11-30-2022
22:49
09:04
DavideFitbit
Trouble is I have to do this every time to get any data on my Charge 5. Complete rubbish
Best Answer12-09-2022 09:04
12-09-2022 09:04
Hi, welcome to the Fitbit Community forums, @Frostinator588 @SunsetRunner.
Thank you for sharing that you've been experiencing this inconvenience with your Charge 5 and for confirming that you already tried the troubleshooting steps suggested.
I've been informed that you already contacted the Customer Support team for further assistance with this and it seems they've provided you with some instructions. In this case, I recommend that you continue the communication with them so they can let you know how to proceed.
See you around.
