Unexpected turn off Charge 5
Hi,
I've had my Charge 5 for 4 months now and it happened a dozen times that unexpectedly shut down even though the battery was at 50-70%.☹️
Does anyone of the forum members know how to fix this?
Many thanks for hints
Moderator edit: format
1 REPLY 1
Hi,  welcome to the Fitbit Community forums, @JTad.
Thank you for all the information that you've shared about this inconvenience with your Charge 5.
Please let me know if when the Charge 5 turns off, you are able to turn it back on or the screen stays completely black and unresponsive. In the  meantime, make sure to complete a three pulse restart:
  1. Connect your device to the charging cable. For instructions, see How do I charge my Fitbit device?
  2. Press the button located on the flat end of the charger 3 times (end of the USB cable), pausing for 1 second between presses. Then wait 10 seconds or until the Fitbit logo appears.
I'll be around.
