Using charge 4 while charge 5 is charging
I have a charge 4 and a Blaze and have bought a charge 5 . When I installed ( started up charge5) it automatically deleted my charge 4 from my devices list.  I want to use both…one functioning while other is charging etc. Is this not possible?
5 REPLIES 5
Sorry, but that is not possible.  You could with the older Blaze, but most of the newer models cannot coexist.  You could use the Blaze with the Charge 5, but not Charge 4 and 5 together.
From Can I use more than one Fitbit device with the same account?
Too bad was using the Versa and charge 4, but was sure I had used the charge 2 &3 at same time at one point
Charge 2 and 3 - yes.  Reread the quote in blue box above; does not include Charge 2.
Charge 2 same situation as Blaze - can co-exist.
Hello @peppermint24 and @JohnnyRow
Sorry to interrupt, but have you thought about just topping up the battery every day rather than letting it run down and need a longer charging time?  I charge mine every day while I'm in the shower, and I don't need to spend that much time without it. I only manage to get it to 99% in that time, but that's good enough for me.
I don't think it hurts the battery too much to charge it a bit every day (I might be wrong though).
I know I can charge daily and I often do but I like the option of more than one up and ready. Especially as I like the size of the face on Versa but appreciate the GPS in charges. At one point I also was using a Surge and had them all in my app at the same time. Thanks
Sent from my iPad
