Had Iconic and worked great, until it wouldn’t sync because of recall. So purchased Charger 5. Main item I keep my phone on silent so it won’t go off during meetings and I don’t have to remember to switch it off and on. My watch would vibrate when I received a call. The Charger 5 is vibrating when I get a call, the PROBLEM it continues to vibrate during the call. Very irritating. How can I fix the issue. I see Blaze has or had the same issue.
Best Answer@DDM51 I think what is happening is that the Charge 5 is trying to tell you that you're on an Active Call, so it vibrates, however the problem is that it repeatedly vibrates over and over to tell you you're on a call. I truly do not know how to fix this, but I wanted to let you know that it's been an issue for sometime now and from what I know, there isn't a fix for it. 😕
You could try going through and unpairing the Charge 5, turning off bluetooth, turning off call notifications in the app, and then set everything back up again, but in my experience it doesn't help or fix the issue.
