11-22-2022
06:37
06:25
DavideFitbit
11-22-2022
06:37
06:25
DavideFitbit
I just got a Charge 5 and I’m very disappointed to find the vibration not changing at all when I change it from normal to strong. I think I’ll send it back as it doesn’t wake me up in the morning and I have missed calls today. The vibration is just too weak.
Moderator edit: format
06:24
15:32
11-25-2022
06:24
15:32
Hi, thanks for sharing that you've been having this inconvenience with your Charge 5, @Timicus .
If you already tried adjusting the vibration strength on the device's settings, please make sure that you've tried restarting your device using the charging cable as well:
Let me know if you notice a different in vibration strength after the restart and after you change the settings one more time.
I'll be around.
12-12-2022 00:16
12-12-2022 00:16
Sadly, it just doesn’t wake me up in the morning, so I’ll have to send it back. I can’t recommend anyone who uses this as an alarm clock buys one of these.
Best Answer12-24-2022 07:47
12-24-2022 07:47
@Timicus Thanks for sharing this update.
I'm sorry to see that your alarm isn't waking you up in the morning. If you haven't done so already, I would recommend that you vote for this idea posted in the Feature Suggestion board of the Community, since this section is regularly monitored by the team of developers: Increase alarm vibration sensitivity and duration on Charge 5.
Thanks again for sharing all your feedback and comments about this.
